Timing belt confusion
Old Jan 6, 2016 | 04:32 AM
  #31
Lancerguy2013's Avatar
Originally Posted by korner
I think the lesson here is that always buy a car with an engine with a timing chain . All the interference engines should have timing chains. You wont have to worry about a belt breaking and old timing chains give you plenty of warning when they start to stretch/loosen. Give me metal any day over rubber. Does anybody know about reliability of the Lancers? I'm thinking of buying one cause I like the 10 year powertrain warranty on both the transmission and engine.
I would have to agree...I like my chances better with a timing chain any day.The trend seems to be leaning toward chains in general...kinda like the old days?...when we had the big V8's... I've had 4 Lancers...only 2 with higher mileage...my 03 had almost 300,000 km...and I did the belt once...and my 09 ..with the chain..I put 210,000 km on it with nothing but regular maintenance.
From what I understand, talking with various Mitsu techs...these cars don't really break...as long as you keep up some decent maintenance.
I have a 2015 Outlander SE AWC...2.4 with the chain. I drive about 40,000 km per year and plan on keeping it at least 4 or 5 years worry free. I think Mitsu is the best brand out there for value...with the excellent warranty you cant go wrong.
Old Jan 7, 2016 | 08:17 PM
  #32
Clint S's Avatar
We have 6 Mitsui's in the family and they all have been stellar with minimal repairs.
Old Jan 8, 2016 | 06:23 AM
  #33
The Silent Seed's Avatar
Clint - which ones, if any, have timing chains ?
Old Jan 9, 2016 | 02:15 PM
  #34
ccernst's Avatar
The 6b31 did start out as a non-interference engine...they removed the divot in 2010 to increase compression.
Replacing it yourself is quite a job, but makes it only cost very little.
Old Dec 28, 2021 | 04:19 PM
  #35
billyhoyle's Avatar
Hoping someone sees this old thread bump...I'm coming up on a timing belt change on a 2013 XLS V6 and I'm wondering if the "crankshaft wrench" (MD998716) is absolutely necessary or if there's a way to turn the crankshaft using another method to align the timing marks. This is really the only question I have about the job...the rest I can figure out provided I can get the crankshaft pulley off!
Old Dec 29, 2021 | 12:14 AM
  #36
DibbyDibbyDJ's Avatar
No. Tool is not necessary
Old Dec 29, 2021 | 06:02 PM
  #37
billyhoyle's Avatar
Perfect. So you can get a regular socket on it or what's the deal?
Old Dec 29, 2021 | 11:59 PM
  #38
Not sure of what that tool is. The only tool i use is a generic 2 pronged tool that goes into 2 holes on some harmonic balancers. This holds it steady whilst you torque the bolt up. Normally i undo them by jamming a breaker bar up against the chassis rail and crank the starter. Some people will not like that way, but i have done it many times over the last 30 years of working in the trade and never had a problem
Old Dec 30, 2021 | 01:55 PM
  #39
billyhoyle's Avatar
Right, I'm with you. You're talking about removing the crank pulley, but what I'm wondering about is the special socket to turn the crank to get the timing marks aligned.
Old Jun 30, 2022 | 11:20 AM
  #40
billyhoyle's Avatar
Follow up - I completed the timing belt job over the past few days. I ended up renting a huge impact wrench to get the crank bolt loose and just reinstalled the bolt and washer to turn the crank by hand to line up timing marks. Not a terrible job, and the service manual is pretty bang on. I ended up making a pulley holder with some 1/4" steel bar and 1/2" bolts...I bent the bolts a bit trying to loosen the crank bolt with a breaker bar/pipe, but it worked just fine to torque it down in the end. A big c-clamp worked just fine to compress the tensioner to bleed it.
At just under 168k km my old timing belt looks pretty mint, but it has stretched a sliiiiight bit compared to the new one.
