Timing belt confusion
Old Jun 30, 2022 | 06:48 PM
  #41
OutlanderGT's Avatar
My 2011 Service manual does have a line that says loosen the center bolt of the tensioner pulley before removing the belt.
And then never say anything about tightening up, this seems to be a copy and paste error from other mitsubishi model's service manual, where you have to use a 2 prong tool to set a partial tension tension, and the center bolt is actually to hold the eccentric tensioner pulley.
Old Aug 2, 2023 | 07:33 PM
  #42
Sammie-sea's Avatar
Originally Posted by billyhoyle
Follow up - I completed the timing belt job over the past few days. I ended up renting a huge impact wrench to get the crank bolt loose and just reinstalled the bolt and washer to turn the crank by hand to line up timing marks. Not a terrible job, and the service manual is pretty bang on. I ended up making a pulley holder with some 1/4" steel bar and 1/2" bolts...I bent the bolts a bit trying to loosen the crank bolt with a breaker bar/pipe, but it worked just fine to torque it down in the end. A big c-clamp worked just fine to compress the tensioner to bleed it.
At just under 168k km my old timing belt looks pretty mint, but it has stretched a sliiiiight bit compared to the new one.
Hey Billy,
I'm considering having my private mechanic take a crack at this as he's been reliable. Where do you get the service manual? I'd like to bring it for him if I do get him to do the work.
Old Aug 3, 2023 | 09:52 AM
  #43
billyhoyle's Avatar
I used this online one for my V6, specifically the section 11D - Engine Overhaul <6B3> -> Timing Belt: [W/M]OUTLANDER (CW#)
As far as I can remember it was pretty spot on...might have been a minor difference here or there, but got me (a home mechanic) through it, so it should be more than enough for a pro. It has torque specs for everything too.
Mine is a 2013, but I used the 2012 manual and it was fine.
dirt.devil
Nov 27, 2018 10:45 PM
Jalapeno
May 14, 2010 09:47 PM
packlad
Oct 17, 2009 02:45 AM
guilianno88
Jun 6, 2008 03:51 PM
eclipseRS21
Feb 7, 2006 10:18 AM
