Tires?
Old Jul 3, 2008 | 12:24 AM
fmgags's Avatar
Default Tires?
Looking for some help here. Want to get some all terrain tires for my 07 outlander xls. Can I move up in size? What max size will fit with no problems or do I have to stick with the lower profile tires.
Thanks in advance.
Old Jul 3, 2008 | 11:36 AM
Elisha's Avatar
Default RE: Tires?
on a 7" rim you should be able to go to 235 no problem.
Old Jul 4, 2008 | 09:58 AM
bnilguy's Avatar
Default RE: Tires?
You'll want to have the same diameter of the tire. Changing this too much will throw off your speedometer and potentially impact your fuel economy. 235 refers to the width in mm...the number before the speed rating/radial designation refers to the height of the treadwall as a ratio to the width. 235 refers to the width in mm...the number before the speed rating/radial designation refers to the height of the treadwall as a ratio to the width...so if you were to go with a 235 and keep the diameter, you would have to go to a lower profile tire.
If you want higher profile, then go to a 17 inch wheel
Old Jul 4, 2008 | 10:37 AM
dsm1990gsx's Avatar
Default RE: Tires?
Check www.tirerack.com for tire prices and reviews.
Old Jul 13, 2008 | 11:17 PM
bioturbo's Avatar
Default RE: Tires?
max up to 105 should be ok
pattonme
Jan 23, 2004 11:37 AM
Nicko
Jan 15, 2004 04:43 PM
AudiTuner
Dec 13, 2003 04:57 AM
azkh
Sep 15, 2003 05:13 PM
SasSi
Aug 12, 2003 02:19 PM
