Transmission
Old Feb 15, 2022 | 04:27 PM
hailiebee's Avatar
Default Transmission
Does anyone know where I can purchase a transmission for a 2016 Mitsubishi Outlander 4WD 2.4L, apart from the dealer
Old Feb 16, 2022 | 03:06 PM
daem0n's Avatar
I did not select exactly your model, but look here.
Old Feb 16, 2022 | 04:31 PM
hailiebee's Avatar
Thank You. I'll check it out.
Old Feb 17, 2022 | 02:00 PM
hailiebee's Avatar
Does the North American Mitsubishi Outlander from 2016 uses the W1CJC-2-A1X Transmission?
Old Mar 3, 2022 | 02:59 PM
Da-man's Avatar
I have a 2016 outlander set as well, can I ask what your issue was with the transmission. I am curious because and transmission "expert" told me I needed a new one for a fluid pressure sensor switch.
Old Mar 5, 2022 | 09:53 PM
hailiebee's Avatar
Apparently the oil cooler went bad and caused trans fluid and coolant to mix causing the transmission to shudder. I took it to the dealer and they told me I needed a new transmission. I have since bypassed the cooler and drained the old oil. It still shudders but not as bad....A new transmission is way too expensive so I'm seeking a used one to buy.
Old May 1, 2022 | 10:47 AM
Truwarrior22's Avatar
Yikes, is this what happened? Wonder if this could be a recall at some point? Perhaps the filter was clogged and caused an increase in pressure which caused the cooler to fail?
JOHNSL
Jan 21, 2022 04:37 PM
pack
Oct 22, 2019 08:29 AM
kmpiotrowski
May 15, 2016 07:19 PM
jessie29
Mar 1, 2016 02:45 AM
Ldvoustovka
Feb 11, 2016 03:47 AM
