Transmission cooler???
Just for my peace of mind... Is there a transmission cooler on my 08 4x4 xls???
I don't tow a lot but i sometime tow 8' trailers and my tent trailer that weights 1850 lbs. i know the towing capacity is 3500 lbs but i did'nt even check if there was a factory installed transmission cooler.
If you have the tow package on the V6, you have a transmission cooler built into the radiator. All Canadian V6s have the tow package, not sure about the US ones. Check for a couple of small hoses going into the radiator and then down under the engine. That's transmission fluid for cooling. If you have a 3500lb tow rating, you have the cooler. Other than some sag on the rear end, you'll have no troubles with that trailer.
you've got the cooler.
