Transmission cooler???
Old Sep 9, 2009 | 07:55 AM
steph1693's Avatar
Default Transmission cooler???
Just for my peace of mind... Is there a transmission cooler on my 08 4x4 xls???
I don't tow a lot but i sometime tow 8' trailers and my tent trailer that weights 1850 lbs. i know the towing capacity is 3500 lbs but i did'nt even check if there was a factory installed transmission cooler.
Old Sep 9, 2009 | 09:22 AM
tcp's Avatar
tcp
Default With the tow package on the V6
If you have the tow package on the V6, you have a transmission cooler built into the radiator. All Canadian V6s have the tow package, not sure about the US ones. Check for a couple of small hoses going into the radiator and then down under the engine. That's transmission fluid for cooling. If you have a 3500lb tow rating, you have the cooler. Other than some sag on the rear end, you'll have no troubles with that trailer.
Old Sep 9, 2009 | 09:59 AM
azjake's Avatar
I have a US model 08 ES with the 4 cylinder engine. It has a transmission cooler (black in color) that you can see by looking into the lower part of the grill.
Old Sep 9, 2009 | 10:06 AM
steph1693's Avatar
Will look tonight, have to move the tent trailer. It is a XLS V6 4wd Canadian model but the hitch is aftermarket, installed by a hitch and trailer cie instead of mitsubishi.
Old Sep 9, 2009 | 12:01 PM
tcp's Avatar
tcp
Default all canadian v6s have it.
you've got the cooler.
Old Sep 9, 2009 | 10:27 PM
Manybrews's Avatar
all have 2 coolers.
DONT modify it. at ALL.
Old Sep 10, 2009 | 10:30 AM
tdford's Avatar
Would someone verify that if you have a v6 4wd that it came standard, US or Can...
Old Sep 12, 2009 | 08:31 AM
Manybrews's Avatar
all outlanders have 2 coolers.
as i said, DONT alter it.
Incisen
Jan 10, 2017 03:51 PM
Gen-8
Nov 24, 2012 01:24 PM
Stonedaily
Nov 2, 2006 09:45 PM
jcdthird
Jun 17, 2005 12:50 PM
w8ing
Jun 13, 2003 07:21 PM
