Transmission slippery...
Hello, I would like to know if anyone else have notice a slippery trani went the weather outside is under 0 degre. Until a few corner, the transmission slip but after a 5 minutes drive everything seems to be back to normal. I think that the transmission have a heater to kept it hot is it true.....If you have experience the same problem give me some info....Thank you!!!
Yes I have the V6, and he's doing it only when I stop at the corner and when I push on the gas pedal, it look like the trani does want to go on,seems like it is slipping.....but after a few corner everthing is back to normal.
There is a TSB for transmission reprogramming. Have it performed by your dealer.
https://mitsubishiforum.com/m_167936..._2/key_/tm.htm
Tom
06-25-2004 10:40 AM
