Transmission slippery...
Old Nov 20, 2008 | 05:42 AM
piper's Avatar
Default Transmission slippery...
Hello, I would like to know if anyone else have notice a slippery trani went the weather outside is under 0 degre. Until a few corner, the transmission slip but after a 5 minutes drive everything seems to be back to normal. I think that the transmission have a heater to kept it hot is it true.....If you have experience the same problem give me some info....Thank you!!!
Old Nov 20, 2008 | 09:39 AM
Elisha's Avatar
Default RE: Transmission slippery...
should be the other way around. slip when warm and rough when cold.
have you checked your tranny fluid?
do you have the v6?
Old Nov 20, 2008 | 05:26 PM
piper's Avatar
Yes I have the V6, and he's doing it only when I stop at the corner and when I push on the gas pedal, it look like the trani does want to go on,seems like it is slipping.....but after a few corner everthing is back to normal.
Old Nov 21, 2008 | 09:53 AM
tcp's Avatar
tcp
There is a TSB for transmission reprogramming. Have it performed by your dealer.
https://mitsubishiforum.com/m_167936..._2/key_/tm.htm
Old Nov 21, 2008 | 10:00 PM
BrodyGuy's Avatar
are you allowing your vehicle to warm up sufficiently?
glennsafrit
Oct 25, 2004 12:29 PM
khscott
Aug 15, 2004 02:38 AM
LESLEY
Jul 19, 2004 08:35 PM
stbmotors
Jul 10, 2004 05:29 AM
