Trunk 12v power
Old May 23, 2024 | 12:40 PM
ben12's Avatar
Default Trunk 12v power
looking to add a low powered winch into the trunk of my 2014 outlander sport and need to get 12v 15amp connection somewhere into the trunk. should i run a whole set of new wires from the battery/fuse box or is there already auxiliary power back there i can tap into?
Old May 27, 2024 | 05:29 PM
MalcNZ's Avatar
If it was me , yes run some correctly rated wiring direct from battery and including its own separate fuse ,then if a fault should occur you will only loose that item in the circuit. Any other wiring will have other items running off it.
steve kelly
Jun 29, 2025 12:48 PM
Alex2420
Jul 5, 2022 03:50 PM
Homer1959
Nov 24, 2020 05:10 PM
Gstfat
Mar 27, 2007 10:56 AM
Flipz
Jan 20, 2005 03:21 PM
