Turn Signals On dash Double Flash --- Please Help - Wiring Diagram?
Old Jun 6, 2013 | 05:16 PM
tepelena's Avatar
Unhappy Turn Signals On dash Double Flash --- Please Help - Wiring Diagram?
I just got a 2006 Outlander and the turn signals on the dash both of them flash regardless if I am using the left or right turn signal. The signals on the outside function properly is just the dash arrow both flash. And when the hazard button is pressed the arrows on the dash don't flash at all. Outside the car they flash properly.
So far I have done a lot of reading and believe this is a ETACS issue.
Can someone please help. Have you seen this problem before?
It will be great if someone can help me with the wiring diagram of the ETACS unit. I already pulled the ETACS out, but the flasher relay is an integrated part of ETACS so I can't just replace it.
Thank you for taking your time to read/help.
Old Jun 8, 2013 | 09:20 AM
tepelena's Avatar
Bump.
No one has had this problem?
Old Mar 16, 2017 | 07:28 AM
Eddiee's Avatar
hi I have the same problem when I turn right or left signal outside works normal but in the dashboard instrument both left and right lights flash can someone help me to fix it thanks
kind regards
Old Mar 23, 2017 | 12:28 PM
tepelena's Avatar
For those who are wondering the solution to this problem has been described here. I had the same issue.
https://www.youcanic.com/vehicles/mi...ter-mitsubishi
Old Nov 5, 2020 | 03:06 PM
Ben Skirvin's Avatar
Hi. Did this get fixed? I'm having a similar issue, but the link is broken. Any help would be appreciated.
Thank you.
nephtali
Nov 11, 2014 07:44 PM
thinhnhan
Aug 19, 2014 02:21 PM
cdvyas20
Dec 19, 2012 11:21 PM
claytonkobe
Sep 19, 2010 12:28 PM
tyson724
Nov 14, 2008 06:00 PM
