Upgrade Instrument Gauge Cluster??
Well, 2013 Outlander does have color screen here. If this is from a Lancer, it might be the reason. Otherwise, my only guess is that the computer gives it the signal for the red screen and it's exactly what I get. Very unfortunate!
The computer doesn't feed video signals to the display and it's very doubtful they would put a function to make it a single color.
What are the icons layouts like on the LCD of the display you bought, can you take a picture??
A couple of thoughts:
1. the 2013 Outlander was a different body style and may have a different cluster....not sure if that is the case for the Lancer. Or, perhaps some of the non-us models continued to use the red cluster.
2. Have you considered the idea that you were given the wrong part? I doubt that an LCD screen would suddenly go red.... that doesn't make any sense. Call the place you got it from or check the part number... sounds like you bought the wrong part.
If you look at ebay motors canada, view vehicles for sale you can see what the color guage cluster looks like. The easiest way to tell is if you look at the speedo and tach. You can see a double bar around the perimeter of the guages instead of the single bar or tick marks.
I don't think my part number will help you because you need it in KM/H and not MPH.
Hello guys! I'm Marcelo, from Brazil. Firstly I want to thank GGGplaya for the beautiful tutorial, with your help it was really easy to do the panel replacement. Now I noticed a problem after a few days: as soon as I turn the key, the mitsubishi logo (during the welcome and check screen) does not appear anymore! Only the gear, temperature and fuel indicators appears.
I tried several ways to reset the panel, and unplugged the battery for hours even, but nothing works.
Anyone have any idea what that might be? I confess that the logo was one of the things that made me buy the color panel.
tks!
tks!
Hi All,
Reviving a very old thread here,
I replaced my 2006 Outlander's gauge cluster (PN8100A112) with one from a 2013 model Lancer, I actually wanted the color display but made a mistake when I ordered it and got one with red display, a bit disappointed but I still like the layout with the speed on the right hand side more and it is much brighter than my old display.
I am getting a code with this new display, cannot remember the code, but it was something in the line of a secondary Can-B device has been connected, I'm suspecting its the 2006 ETACS that does not talk to the newer modules?
My biggest issue is that when I turn the 4WD **** between the seats, the new cluster does not show that 4WD has been turned on, put the old cluster back and it shows the 4WD is turned on.
Why would every other thing work on this cluster but it will not show the 4WD on the LCD? is that something that is built into the firmware? I've checked every setting in MUT3-se but could not find anything that can be set on the cluster.
Thanks
Thanks
opplocker
Aug 8, 2010 09:41 PM
crios2307
Feb 16, 2010 12:15 PM
