Verry poor rear brakes Outlander II 2008
Old Dec 5, 2019 | 03:25 PM
Raiz3n's Avatar
Default Verry poor rear brakes Outlander II 2008
Hello, firstly i want to say hello to everyone on this forum and also want to apologize for my english. I tried to find a solutions on forums in my language but there is nothing to find, so i decided to ask for jelp here. I have a problem with rear brakes, they doesnt work like they should. Front brakes are braking perfectly but the rear brakes are braking verry poor. I made a regenaration of clamps at the back, brake disk and pads are okay, elastic fluid wires are good too. I saw only one issue, the fluid pressure is verry low. At front brakes the fluid is squezzing when i push pedal but in rear brakes its only leaking. So after few kilometers front brake discs are verry hot, much more than back discs. Anyone know how i could fix that issue?
Old Dec 8, 2019 | 03:19 PM
ccernst's Avatar
First thing to check is pressure for rear lines at abs module.
Have brake fluid changes occured regularly?
Old Dec 8, 2019 | 03:46 PM
Raiz3n's Avatar
I have a tool to check compression on pistons, can i use it to check the pressure on abs pump or there is a much bigger pressure than it can check? Is there a something like brake force corrector between pump and clamps? I bought this car 2 months ago and i changed the brake fluid. I think the
Previous owner of this car didint change it for a long time, there was a white foam when i pumped pedal to get the air out from brake wires.
Outlanderishness
Oct 20, 2019 05:09 PM
Themax24
Jul 23, 2018 09:21 PM
msport_2_outlander
Jan 9, 2015 07:30 AM
Brucy2000b
Sep 24, 2012 10:59 PM
klas
May 16, 2009 04:24 PM
