Warm Up Catalytic Converter Efficiency Below Threshold
Old Oct 3, 2022 | 10:59 PM
MalcNZ's Avatar
Similar issue with my V6, but message usually is PO431 (same problem but front cylinder bank) No extra noise from exhaust than normal, usually when cold and wet. replaced O2 sensors but issue returns again. 230,000kms on vehicle, no oil usage and runs just fine so maybe the cats are getting blocked. Looking for suggestions
Old Oct 3, 2022 | 11:08 PM
Galantralliart09's Avatar
I cleaned MAF sensor with electronic cleaner and I put premium fuel. The service engine light went away on its own. You could try that.
Old Feb 22, 2023 | 11:35 AM
Danubi's Avatar
Default Any updates?
Originally Posted by Truwarrior22
Makes sense, very intermittent though, it seems as if it only comes on when it’s damp or raining. Did you notice any additional noise with the flex pipe leaking?
I am having the same problem and it fixes itself when it rains. The rain seems to affect the problem in some way. Any updates or solution?
Old Feb 22, 2023 | 11:41 AM
Had to replace catalytic converter on mine. Luckily it was under the 80k mileage warranty period. Heard it was a common problem on some Outlanders.
Old Feb 22, 2023 | 05:12 PM
Truwarrior22's Avatar
Did you have any performance issues or just the check engine light? I put in some fuel injector cleaner and pushed the engine to redline for a little while. Light shut off for a month or so but back again.
Old Feb 22, 2023 | 06:29 PM
I did not notice any performance issues. Just the check engine light.
Old Feb 23, 2023 | 09:46 AM
Thanks, also happen to know which one they replaced? Looks like there maybe two? One on the manifold and one after the manifold? Unless it’s just a resonator, etc.
Old Feb 23, 2023 | 09:51 AM
They replaced the catalytic/manifold one.
Old Mar 12, 2023 | 10:13 PM
Thanks, just changed my spark plugs at 100K miles. Light went off after a few trips, we’ll see if it comes back on. It’s toying with me lol
Old Mar 13, 2023 | 02:40 AM
Danubi's Avatar
Default Thanks
ive heard the same thing as well. Im going to remove it and try a way to clean the catalytic converter because it's a really expensive part. Thanks
