which way does the spare tire store?
Old Aug 27, 2012 | 08:00 PM
OutlanderGT's Avatar
Default which way does the spare tire store?
I was trying to check the pressure of the spare tire and noticed the factory installed the spare tire under the back of the car, with it facing up so it can't be aired up unless I drop the spare tire down.
I also see a sticker that says (if you can see this sticker you have installed the wrong way) I assume that's sticker meant for mounting on the vehicle.
Just wanted to know if the tire should face up (hub side facing the ground) or the other way.
Old Aug 27, 2012 | 11:29 PM
Gen-8's Avatar
Lol I'd say hub is road side or ring might fowl undercarriage lol
Old Aug 28, 2012 | 07:12 AM
milliesdad's Avatar
I'd guess that it stores the way the factory put it.
That's why you have got the Mitsubishi roadside assistance. Didn't your sales guy explain that part?
Old Aug 28, 2012 | 08:00 AM
Claude_A's Avatar
Hub up, just like you found it.
It force you to exercise the mechanism which could get jammed by rust or dirt if you did not.
A major pain when you actually need the spare
Old Aug 28, 2012 | 02:50 PM
Gen-8's Avatar
I totally removed mine and all the other bits of it too.., we never get flats here, touch wood...
Old Nov 7, 2012 | 06:37 AM
milliesdad's Avatar
behind a removable panel on passengers side in cargo area.
deltadawn
Sep 19, 2016 08:29 AM
deltadawn
Oct 1, 2012 08:06 PM
sled driver
Aug 18, 2006 04:39 PM
ilcaa
Feb 26, 2005 07:20 PM
92montero007
Sep 27, 2004 01:38 AM
