What typeof oil should I use?
Old Jun 24, 2010 | 05:57 PM
Superdave777's Avatar
Cool What typeof oil should I use?
We bought a used 2006 Outlander from a Ford dealer and they did all their required dealer maintenance. I do not know the past history on the maintenance with the prior owners. I hear this vehicle should only use Full Synthetic Oil, not blended. It didn't come with an owners manual. We took it in to a quicky oil change place when it was time and they charged $26. At that price I don't think they did a Full Synthetic. Assuming many of the past oil changes were not Full Synthetic, can I start using it or does it rally matter if I use petroleum based oil?
Thanks!
David
Old Jun 24, 2010 | 07:29 PM
I'll let you make your own conclusions.
This is an engine that has used conventional oil for 45k miles.
The owner then cleaned the head completely, and ran it another 45k using synthetic. This is the result:
I know which one I'd rather have....
Now if your question is does it matter switching between the two? Absolutely not, that's a myth.
Old Jun 24, 2010 | 10:26 PM
Amsoil. Yessir, that's the stuff. But a little excessive for this vehicle.
Old Jun 24, 2010 | 10:41 PM
rip14's Avatar
Thanks for those picks sebba
Old Jun 24, 2010 | 11:29 PM
Makes you think twice about using that ****ty conventional, huh?
Old Jun 25, 2010 | 08:36 AM
Thanks for the info Sebba,
I was planning on using Vavoline or Castrol Full Synthetic. That would be ok right?
You mention Amsoil, is that because you are a dealer?
Thank you!
David
Old Jun 25, 2010 | 11:51 AM
tcp's Avatar
tcp
Default Good old Bob
http://www.bobistheoilguy.com/forums/ubbthreads.php
Answers to all your questions and many you didn't ask.
Old Jun 25, 2010 | 04:03 PM
Thank you!
David
No Amsoil is generally the best. I'm not a dealer, and I don't think the other guy above me is.
Out of those two you mention, I'd use Castrol. I personally use Mobil 1 in my car.
way2fast
Dec 22, 2013 08:54 AM
cdvyas20
Feb 19, 2013 06:24 PM
98_GstEclipse
Aug 14, 2006 06:29 PM
shreff99
Sep 24, 2005 01:09 PM
shreff99
Sep 23, 2005 12:11 PM
