Wheel alignment specs
Old Mar 25, 2010 | 10:01 AM
newoutlanderfan's Avatar
Default Wheel alignment specs
Hey all,
ANy idea what the specs for a normal wheel alignment for the outlander is?
I got an aligment done and the according to the sheet, alot of values are not in the normal range..The toe for both front tires are out of range and something for the rear as well (I don't have the specs in front of me)
I am only asking because I have read that some people thought that outlander was odd in some measurements to begin with.
I have a 2009 LS and only 10,000km on it.
Thanks....
Old Mar 28, 2010 | 11:39 PM
Tasman's Avatar
FRONT
Toe in mm
1 ± 2
Steering angle
Inner wheel
38°40’ ± 1°30’
Outer circular <Reference value>
32°20’
Camber
0°20’ ± 0°30’ (left/right difference 30’max)
Caster
2°35’ ± 0°30’ (left/right difference 30’max)
Lower arm ball joint rotation starting torque N·m
2.2 - 4.1
Stabilizer link ball joint rotation torque N·m
0.5 - 2.9
REAR
Toe in mm
3 ± 2
Camber
-0°25’ ± 0°30’ (Difference between right and left within 0°30’)
0.5 - 2.9
Old Nov 15, 2011 | 07:41 AM
jpk36's Avatar
I've got a 2010 GT S-AWC. Are the alignment specs the same for my Outlander?
Old Apr 24, 2012 | 08:45 AM
quixmac's Avatar
Default 2010 Outlander TIRE WEAR
I have 2010 Outlander FWD with 20,000 miles. I did check my alignment and looks tiny off. The most annoying thing is that my tires wear out on the outside. Camber looks within limits. How come my tires are going bold on the outside. PLease advise.
Attached Thumbnails Wheel alignment specs-dscf3963.jpg   Wheel alignment specs-dscf3964.jpg
Old Jan 22, 2020 | 07:37 AM
TooTill's Avatar
I have a 2016 ASX AWD . What is front wheel alignment toe-in spec. please TQ
Old Feb 8, 2020 | 05:25 PM
Kaz's Avatar
Kaz
2014 ASX specs are ... should be same
Toe-in At the centre of tyre tread mm 1 ± 2
Toe-in angle (per wheel) 0°03’ ± 0°05’
Camber 0°15’ ± 0°30’*
Caster 2°40’ ± 0°30’*
Kingpin inclination 13°00’ ± 1°30’
Lower arm ball joint rotation starting torque N·m 7.0 - 9.0
Stabilizer link ball joint rotation torque N·m 0.5 - 2.9
note *: Difference between right and left wheels must be less than 0°30’
Old Feb 9, 2020 | 07:43 AM
TooTill's Avatar
Default ASX Toe in specs
KAZ
Many thanks. I have now checked with a lazer and got my garage to correct their error.
TooTilll
Tpaul
May 21, 2013 02:38 AM
yzrider22k
Sep 23, 2011 11:00 AM
sn22
Apr 9, 2011 09:31 AM
rcastro
Oct 18, 2010 03:04 AM
Tasman
Nov 13, 2009 08:00 AM
