window tint problem
Old Aug 21, 2007 | 09:34 PM
Valerie's Avatar
Default window tint problem
For those who had this problem, what kind of felt material was installed on the rubber strip? How thick and wide is this felt strip? I brought mine back to the dealer. They replaced the tint and supposedly fixed the problem under warranty. Everything was ok for about 3 weeks and now the scratches are back! [:@]
Mitsu girl
Old Aug 21, 2007 | 09:37 PM
Default RE: window tint problem
Thats some buuuuuuuuull**** right there. Hmmmm it shouldnt be abrasive at all. I dont doubt what your saying at all... just trying to think of another solution.
Is it possible the tint is just a low quality tint?
By the way.. when cleaning your windows make sure you use a window cleaner without amonia. It will say on the bottle "safe for tinted windows" Using the amonia stuff is what gives you the ghetto purple windows : )
Old Aug 21, 2007 | 09:57 PM
Valerie's Avatar
The tint was made by 3M:
http://solutions.3m.com/wps/portal/3...beT4DCJBL6BVgl
Only the front door tints are affected. The scratches are vertical straight lines. Dealer told me they've had other Outlander units with this problem and that the rubber strip is held too tight against the window. So they told me they fixed it by loosening up a bit. No felt was installed. I've read in past threads that felt strips solved the problem. What type of felt strips are these so I can forward it to my dealer.
Old Aug 21, 2007 | 10:02 PM
Oh, not cheap then. 3M isnt likely to sell low quality stuff
I really have no idea. Im guessing some kind of synthetic material with the reverse side adhesive so you can stick it to the rubber strip. The dealer should know this sh it.
What i find, is you get contrasting storys from different dealerships. I would try another.. and see if they have anything available that can help you.
Old Aug 21, 2007 | 11:10 PM
wymanc's Avatar
I had the same problem but the shop replaced the tint and installed the felt material. I'm not sure how thick it is but it's adhesive on one side. You have to take the door panels off and remove the liner. Once it's removed you just wrap the felt over the edge of the liner. I would suggest clamping it down and let set for awhile before reinstalling it.
Old Aug 21, 2007 | 11:19 PM
Thats exactly what i thought.
Old Aug 22, 2007 | 07:56 PM
abrcrombe's Avatar
This is for the front side windows? Man, I wanted to get these tinted but don't really want to deal with having to do all this! How much was the install?
Old Aug 23, 2007 | 05:09 AM
wymanc's Avatar
I had all my windows tinted. The front windows scratched a lot more than the rear but I had felt installed on all windows. I think I paid about 250 for the entire install.
Old Aug 24, 2007 | 08:40 PM
Valerie's Avatar
thank you for the replies
Old Aug 24, 2007 | 08:45 PM
Any time. Thats what we're here for : )
nate5023
Sep 22, 2005 04:06 PM
Riptide
Aug 25, 2005 08:39 PM
hereclipse
Aug 7, 2005 02:12 PM
hereclipse
May 31, 2005 12:21 PM
hereclipse
May 26, 2005 02:02 PM
