XLS keyless start
Old Aug 4, 2007 | 02:19 PM
puwit321's Avatar
Default XLS keyless start
Hi: I just picked up a brand new XLS with the keyless start. I was able to start it with just the plastic **** at the dealer ship. But when I got home (200 miles away), I can only start it with the mechanic key. The plastic **** doesn't turn, even when I push it in hard. Is there something that I might have done to disable the keyless start mechanism? Please advise. Thanks a lot.
Old Aug 4, 2007 | 02:33 PM
abrcrombe's Avatar
Default RE: XLS keyless start
I have never heard of this before. Is the plastic cover on correctly? I find that you don't have to push it very hard before turning it.
Also, welcome to the forums!
Old Aug 4, 2007 | 03:14 PM
Manybrews's Avatar
are you sure you have the keyfob in the car?
Old Aug 5, 2007 | 07:58 AM
puwit321's Avatar
Yup...the key is in my pocket. I know the electronics work becausethe doorsunlocks automatically. The plastic **** seems to be on securely clipped on becauseI would have to squeeze the two rubber buttons to remove it. So I guess I have to bring to a nearby dealer for repair.
Another question I have is can I duplicate the mechanic key? Can I disable F.A.S.T feature? Thanks.
Old Aug 5, 2007 | 10:39 AM
evoracer's Avatar
Do you have Nav? I believe there is an option in the programming to change the FAST system. I am not sure if it can vary the starting or just the keyless entry though.
Old Aug 6, 2007 | 05:49 AM
Fisherman's Avatar
ORIGINAL: evoracer
evoracer- excellent thought
puwit321 - I am pretty sure there is an option to disable the Keyless starting in the MMCS. If you have the Nav system and thus MMCS, were youin messing around with the equipment options in the MMCS? You could have changed it to disable the keyless start. It is worth checking before taking it back to the dealer. That would make for a real Homer "duh".
Old Aug 6, 2007 | 01:43 PM
puwit321's Avatar
You guys are the best! It turned out the I messed with the Nav unit. I had "door only" option selected. I changed it back to door and start. Now I can turn the ****. Aparently it has some electro-mechanicrelay that controls the key mechanism. The two dealers I went to were as clueless as I was. Thanks alot.
Old Aug 6, 2007 | 01:59 PM
abrcrombe's Avatar
Wow, sounds like a slip up. I like to explore in the menus, I better be careful what I change.
Glad it got fixed
Old Aug 6, 2007 | 07:57 PM
evoracer's Avatar
You're welcome. And congrats on the purchase and welcome to the forums BTW.
Old Aug 7, 2007 | 06:42 AM
Fisherman's Avatar
Glad we could help. To me, that is really the point of a forum like this.
christech
Jan 9, 2014 10:41 PM
98 Monty
Dec 19, 2010 02:53 PM
dahoopd
Nov 4, 2010 08:10 PM
rjuskov
Dec 10, 2008 11:37 PM
davehking
Dec 20, 2007 04:56 PM
