1993 1.8 problems
heres the story, did a rebuild on the car evrything is back on, i have spark,fuel is present. my injectors dont have any juice to fire the injectors. i put a noid bulb on all 4 and get nothing. the car will start to run if i spray starting fluid in the throttle body . fuel pressure is good is it the distributor or the ecm how can i test it.
Are the injectors "clicking"? If you don't know, place the blade of a long screw driver on each injector and hold the handle to one of your ears. If the inj IS working, you'll hear a clicking sound. If not, my guess would be ECU related.(You state there is spark)
By any chance did you disconnect the the ECU connectors and NOT get one completely re-connected?
