1993 1.8 problems
Old Aug 20, 2007 | 01:35 PM
tampabaymitsu's Avatar
Default 1993 1.8 problems
heres the story, did a rebuild on the car evrything is back on, i have spark,fuel is present. my injectors dont have any juice to fire the injectors. i put a noid bulb on all 4 and get nothing. the car will start to run if i spray starting fluid in the throttle body . fuel pressure is good is it the distributor or the ecm how can i test it.
Old Aug 20, 2007 | 09:23 PM
oldrageman's Avatar
Default RE: 1993 1.8 problems
Are the injectors "clicking"? If you don't know, place the blade of a long screw driver on each injector and hold the handle to one of your ears. If the inj IS working, you'll hear a clicking sound. If not, my guess would be ECU related.(You state there is spark)
By any chance did you disconnect the the ECU connectors and NOT get one completely re-connected?
Old Aug 21, 2007 | 02:28 PM
no i didnt pull the ecu. the car wont run on its own like i said there is no power to the injectors i put a light on it and it does not pulse
Old Aug 22, 2007 | 03:47 AM
josh_white_evo4's Avatar
THE INJECTORS R NOT CLICKING...
Old Aug 23, 2007 | 01:24 PM
it was the dizzy she fired right after a trip to the junk yard.....................................whooooooo ohoooooooooooooooo
jp2000
Jan 1, 2012 05:21 PM
jdumsha
Nov 11, 2004 03:22 PM
msun
Jun 22, 2004 05:22 AM
shaidi
Feb 17, 2004 10:39 PM
tweetybird
Dec 1, 2003 08:20 PM
