2017 OUTLANDER ES rear negative camber issue
Old Nov 25, 2020 | 01:04 PM
BigRedBeardo's Avatar
Default 2017 OUTLANDER ES rear negative camber issue
hey guys,
i have a 2017 outlander es...nothing fancy, but ive noticed i have negative camber on the right side, rear wheel.
as far as i know there is no physical adjustment for this value.
ive looked at the ar$ end and cant figure out which part would be causing the issue.
shocks look fine, and are torqued, stabilizer links are not wobbly and are torqued.
control arm bushings seem to be in good condition.
id like some insight from you experienced import folks about where to start.
this is my first import, AND the newest vehicle i have ever owned.
i will be attempting to buy the part(S) from rock auto. just not sure which one(S) to buy
thanks in advance!
-Beardo
Old Nov 25, 2020 | 02:20 PM
DibbyDibbyDJ's Avatar
You need to get a 4 wheel alignment done, to see what is causing your issue.
Old Nov 25, 2020 | 02:31 PM
thanks. as a diy-er i was hoping to avoid shady mechanics. but ill look about for a shop with reasonable alignemt rates
Old Nov 26, 2020 | 12:18 AM
Find one that has good reviews...
erixon84
Apr 19, 2022 02:37 AM
2017ES
Feb 2, 2018 01:43 AM
btufail
Aug 18, 2017 05:56 AM
FieroSS
Oct 5, 2010 12:12 AM
motaz
May 18, 2004 09:34 AM
