99 Eclipse Electrical Help
Old May 31, 2006 | 01:51 AM
nork's Avatar
Default 99 Eclipse Electrical Help
I have a 99 Eclipse that I purchased recently. The previous owner was trying to install a new led in the ring around the ignition key and blew a fuse. When that happened for some reason the power windows would work whether the key was on in the ignition or not. Also the power door locks stopped functioning. Lastly there is now a small draw on the battery which If I dont drive for a few days kills the battery completely. I took the steering column apart and found the 2 wires that where supposed to go to the led just dangling so I shrink wrapped them so they wouldn't short. I then checked all the fuses under the hood and by the drivers side left foot and they all where good. I noticed that when I hit the power door lock there was a relay in another box above the fuse box inside the car that popped when I hit the switch. I replaced this relay and the power windows now work properly (only with the key on in the ignition) but still no power door locks. When I dosconnect the negative battery cable (testing for a short) I also noticed that the door locks would lock one time and then never again unless I pulled the negative cable off again.
If anyone has had a simular problem and has any ideas I would appreciate some feedback. I am still searching for a short but am comming up with nothing so far.
Thanks
Old May 31, 2006 | 05:14 PM
tidus10's Avatar
Default RE: 99 Eclipse Electrical Help
i have no clue on electrical sry...buy wi will say welcome to the forums..try the tech section
01miragels
Oct 29, 2006 06:30 PM
nork
May 31, 2006 01:56 AM
grotesque
Nov 7, 2005 12:47 PM
m3kgt_99
Sep 28, 2004 12:38 PM
