Big Time Engine Problems
Old Mar 22, 2006 | 11:46 PM
jhutch623's Avatar
Default Big Time Engine Problems
Ok here's the deal I have a 1995 Eclipse, I had a supposedly new engine put in by a local mechanic. It seemed to run fine for a few days then I started receiving all these Error codes. P1294, P0340, and P1391. I found these by using a code scanning device I borrowed. Anyway now the the engine idles way too high around 300 or 4000 rpm when evrer I start it up and stays there. After awhile it will settle down and then bounce around from 1500rpm to 2500rpm. Can anyone give me some help on what to do? By the way the mechanic is long gone out of business I think. Last thing the SRS light stays on and Check engine light can be cleared using the code reader.
Old Mar 23, 2006 | 12:09 AM
Silvertooth's Avatar
Default RE: Big Time Engine Problems
One, welcome to the site. Two, that reallys ucks and I wish I could help you out, but I am a 3000GT owner. Thirdly, sorry man but a admin/mod is probably going to move this thread for you to another section.
Old Mar 23, 2006 | 04:51 AM
WIECLIPSEGUY's Avatar
Although this isn't the right section to chat about engine problems, I can just say that you should look into the throttle Poss. sensor. Seems that the computer doesn't know where the butterfly is and because of that the F/A mixture is way off.... OR your computer is trashed and just shooting out codes.... Both will do that! Welcome and Good Luck!
Old Mar 23, 2006 | 08:27 AM
you have a VAC leak or a boost leak. Post this in tech help it wont get any attention in the new members section.
Welcome to the site
MMM83
Jul 30, 2012 06:57 PM
Gstfat
Apr 30, 2008 10:32 PM
burnmyeyes
Dec 14, 2006 12:08 AM
jhutch623
Apr 8, 2006 08:20 AM
puffy
Aug 8, 2004 12:50 PM
