Mitsubishi Montero 05, Engine & Traction light
Old Dec 16, 2011 | 04:41 PM
papa007's Avatar
Default Mitsubishi Montero 05, Engine & Traction light
Hello members,
I'm in Canada,
About 71.000 Km.
Every 3 - 4 month (started about 2-3 years ago) this lights are on with out any reason, or it staring to work like only 2 of 6 cylinders only working,
Or Metal noise from engine (Like no oil in)
Computer found 2 items in Diagnostic test.
1. # PO340 - Camshaft Position Sensor
2. # PO335 - Crankshaft Position Sensor
Mitsubishi mechanic told me that if he will be opening an engine to change it,
He will do:
1. Belt Valve timing
2. Spacer, Timing Belt Train.
3. Blade, Crankshaft Angle Sensing
4. Sprocket, Crankshaft Camshaft Drive
5. Adjuster, Timing Belt Tensioner
6. Sensor, ENG Crank Angle
7. Sensor, Camshaft Position
8. Regulator, MPI Delivery Pipe Pressure
With labor about $ $2,000-00
But the most interesting part of this - that he is not sure if it's will be fixing this...
Hope some body can help me...
grumpy400
Sep 25, 2013 01:33 PM
johvig
15
Dec 9, 2007 12:15 AM
vinceaton
Jun 11, 2005 01:16 PM
xtremeone1998
Apr 5, 2005 12:21 PM
xtremeone1998
Mar 25, 2005 08:57 PM
