(NEWBIE) tranny will not shift into overdrive?
Old Feb 1, 2007 | 11:01 PM
diskretephx's Avatar
Default (NEWBIE) tranny will not shift into overdrive?
I havea 95 diamante out of storage 2 mo.s ago and it seemed to be running fine other than the usual rusty stuff after 2 yrs of storage which is to be expected... Two days ago it will not shift into overdrive every other gear works like a champ, it hits 5th and just rolls the rpm's up.
Had one gentlemen tell me it was a cillanoid and was an easy fix, had another say the noid was in the tranny! please tell me the latter is not true?
Also the check engine light came on last night after rolling to 130,200.... which I figured was the dealers way to hit ya in the wallet when your extended warranty is up. I'm gonna try and reset the computer and see of that helps.
I would like to say that this car rocks and I've never timed it but I have put a few bmw's in thier place goin down the road!!!
If any of you could be of assistance please let me know.
p.s its a six banger
thanx
diskretephx
Old Feb 2, 2007 | 12:20 AM
Default RE: (NEWBIE) tranny will not shift into overdrive?
The problem is your "end clutch". It is in your tranny but its actually pretty simple to fix. My brother just had it done at a shop for his hyundai and they charged him like 500 but i think that was a bit pricey. You dont even have to take the tranny off to do it cuz its right on the end, hence the name . But thats gotta be your problem.
and as far as the CEL. Just take it to autozone. They will run the code for you for free as long as you car has the obdII. Actually you have a 95 so i dont think you do. Just look around under your steering wheel and see if there is a huge plug that isnt connected to anything.
Old Feb 2, 2007 | 12:46 AM
thank you so much, man am I grateful to have you guy's and this forum....
went out andchecked and your exactly right!!! thank you thank you!
Old Feb 2, 2007 | 10:15 AM
no problem man. I guess you can thank my brother too because when he had that problem i was like you looking around and researching to find the answer and thats what i found.
thomcasey
1st Generation
Jul 26, 2008 04:11 PM
brocklanders
Apr 14, 2008 08:57 AM
antlip
Mar 9, 2007 02:36 PM
paulo9469
May 22, 2005 10:29 AM
glenn
May 13, 2004 04:46 PM
