View Poll Results: A poll
outlander trans problem
0%
outlander
0%
help
0%
Voters: 0. You may not vote on this poll
torque convertor problem on 03 outlander
i am working ona 2003 outlander that has a problem with the torque convertor not engaging propperly
the tcc solenoid duty cycle is only going to 96% wich is causing torque convertor to slip at the wrong time makeing
the car feel as though it has a miss i have replaced the torque convertor output and input speed sensors and tps sensor
the fluid has been flushed the tcc solenoid will go to 100% but it takes longer then it should to reach 100 i ran a pressure test
on the torque convertor apply pressure it was normal and you can make the trans go into fail safe and it runs fine so i think it is an electrical problem
