04 lancer es need help!!!!
Old May 30, 2011 | 05:21 PM
lancerES's Avatar
Question 04 lancer es need help!!!!
I have a 2004 lancer ES and i am looking to turbo it!
I have a kit lined up for purchase and i am just wondering where is a place in edmonton or close to it that would INSTALL it and DYNOTUNE it?
AND also how much that would all cost?
Old May 31, 2011 | 11:17 AM
you do realize you cant just install a turbo and go from there. There is alot of other stuff you need like upgraded fuel, new downpipe, intercooler, some piggyback device to tune with, and also the other stuff like a wideband o2 sensor and gauge, boost controller and gauge, ect.
Old May 31, 2011 | 05:03 PM
lancerES's Avatar
Yes I realize that and I have everything except for a few minor things
The pistons and piston rods etc are on their way as well
I was just wondering the cost to install it and where there would be a place that's all
Old May 31, 2011 | 06:20 PM
well if you are also doing internals then you would be better off removing the whole engine yourself and sending the head/block and parts out to a machine shop. That would save you a ton on that end. And the other stuff i would assume are not all that difficult to install. Its all pretty simple stuff if you are somewhat mechanically inclined. If you are not and plan on having a shop do the entire job then i would be prepared to spend $3k minimum. Just to give you a heads up because it will not be cheap, you are talking an entire engine build plus the install of all the components. Then you would be looking at another $400 or so to have someone that knows what they are doing to tune it.
Out of curiosity what did you plan on using to tune it and what kinda turbo setup are we talking about?
Old May 31, 2011 | 10:52 PM
lancerES's Avatar
I was just gonna get it dynotuned and whatever they do is what I would go with plus maybe a piggyback
Honestly I'm not sure it's a guy off kijiji and he says he has EVERYTHING I need I just need a new manifold cuz his is cracked
I haven't gotten around to going to look at it and he replies extremely slow to my emails
Old Jun 1, 2011 | 06:51 AM
well i dotn know a whole lot about how the stock ecu functions for the lancer but i am willing to bet there is no way to tune it without a piggyback or standalone. The trouble is you need to be able to adjust the A/F ratios in order to allow for the increased airflow from the turbo. And i know with almost all cars that is not achievable with the stock ECU setup without some sort of additional hardware.
I wouldnt take his word for it as "Everything" unless he gave you can exact list of the parts you are getting.
Old Jun 1, 2011 | 09:45 AM
lancerES's Avatar
Well then looks like I'm getting a piggyback sometime soon
No he just gives the price and his phone number
He does say however it came off his 05 lancer and mine is an 04 so I'm pretty should everything will fit cuz they are the same from 02-06
I still have to look more into it I just wanted to find out some prices and if anyone knew of any places I could get it done
method.
Nov 22, 2006 04:39 PM
Dan Smith
Nov 18, 2004 01:06 PM
Dan Smith
Oct 27, 2004 10:38 AM
mmarino
Jun 17, 2004 02:59 AM
wutdadill
Apr 29, 2004 09:39 AM
