#3 cylinder misfire
Old Jul 21, 2007 | 07:10 PM
ck76's Avatar
Default #3 cylinder misfire
hey everyone... i have a 98 eclipse and i have a #3 cylinder misfire. i have a msd ignition & wires. i pulled out the old plugs,,they looked good by were cheap *** champions so i installed new ngk plugs but am still having a missfire. eng light is flashing.......pleaase help me!!!!!!!!!!!!!
Old Jul 21, 2007 | 07:48 PM
Kaede.Noir's Avatar
Default RE: #3 cylinder misfire
By ignition do you mean the coil pack? if you have the amp, maybe you fried it? check the pack, no prob with the plugs
Old Jul 21, 2007 | 08:57 PM
ck76's Avatar
i have the msd coil pack. what is the amp????
Old Jul 21, 2007 | 09:33 PM
ck76's Avatar
i've done a few thread searches and it sounds like the coil goes out alot on the #3 cylinder???? do i have to replace it of just clean the terminal?
Old Jul 23, 2007 | 02:07 AM
Kaede.Noir's Avatar
you could try cleaning the terminal, the amp, is kinda like a sound amp, but made to push in more volt through the coil (if my memory serves right) and, yeah... somehow it does... in the 420a, which engine you have again?
Old Jul 23, 2007 | 10:56 PM
I Drive Naked's Avatar
One other thing to check is fuel to the cylinder.
You might have an inkector not spraying.
Old Jul 23, 2007 | 11:13 PM
ck76's Avatar
well today i took it to my work (i manage a auto shop)not ignition related,,,coil is good, splug & wires good. swaped out my msd for new/stock parts and got the same prob with the motor 420a...... this is what i thing,,,,,, it has a turbo 8lbs of boot, nitrus, reprogramed ecm & diff fuel inj & 2 stage fuel pump,,,under low to med accel. the car runs good,,,,under hard accel the car starts to sputter like it is starving for fuel???? i think the inj. on the #3 cylinder might be getting cloged up when the 2nd stage fuel pump engages?????? the car has a good idle and seems to run great at low rpm's
nightime25
May 31, 2009 09:04 PM
570cizan
Dec 25, 2008 08:21 PM
rcmaster
11
Nov 1, 2007 03:22 PM
dcvee
33
Aug 8, 2007 06:41 PM
signtist2004
Oct 19, 2006 11:01 AM
