60-1 trim turbo?
Old Jan 13, 2008 | 09:42 PM
newguy2007's Avatar
Default 60-1 trim turbo?
What exactly is the 60-1 trim turbo? In size? Ive heard about 16g and 20g and now 50 trim and all different measurments. I have the 60-1 trim in my car and it spools up pretty nice.
Also, i was just wondering about a hp estimate for my car. I think im going to get it dynoed pretty soon but until then: 97 eclipse gst spyder
650 cc fuel injectors
bigger fuel pump(?)
FMIC
greddy bov
wastegate
60-1 trim turbo
safc II
hks valve controller
running 25 psi boost
turbo timer
full 3" exhaust
running 93 octane fuel
manual (brand new clutch friday)
I think thats about it.
Old Jan 13, 2008 | 10:17 PM
Default RE: 60-1 trim turbo?
That turbo is actually pretty massive. Itsbigger than a 50 trim. Its about the equivilant to a 30R. Basically a 500hp capable turbo.
Total overkill with your mods
Old Jan 13, 2008 | 10:23 PM
newguy2007's Avatar
as long as it still spools up nice does it matter?
Old Jan 14, 2008 | 07:47 AM
You do have a wideband also right. Make sure your running a good A/F ratio. And i think at that PSI your really pushing the limits of that SAFC. You might want to think about upgrading to DSMlink or something. I would turn that boost down a bit to like 20 until your sure your running at a safe a/f.
But for an estimate its hard to say because the tune will really change it. If i had to guess id say no more than 320 only because of the safc. Its definetly capable of the 400hp+ though
Old Jan 14, 2008 | 12:18 PM
If you are okay with it... then its just fine.
However, you can get the same power from a much smaller turbo, and you will have better spool.
Old Jan 14, 2008 | 06:52 PM
TheAdvocate's Avatar
Im suprised your motor is handling that size of turbo at 25 psi... Should be pretty quick though..
Old Jan 14, 2008 | 07:24 PM
thats what im wondering advocate. Especially only on an SAFC. It doesnt add up to me.
Old Jan 14, 2008 | 10:00 PM
I bet its knocking like a ****
Old Jan 14, 2008 | 10:07 PM
newguy2007's Avatar
someone else told me this too. I will check the psi tommorrow and try to turn it down to about 20.(once i figure out how to use the ****ing hks)
Old Jan 14, 2008 | 10:08 PM
jlh077464's Avatar
So did you have a wideband?
