60-1 trim turbo?
Old Jan 14, 2008 | 10:32 PM
newguy2007's Avatar
Default RE: 60-1 trim turbo?
im thinking of buying one soon. Im gonna check them out right now.
do you know a sight where i can get a tutorial for using the hks valve controller or the safc 2? And if i buy the wideband do i need the safc?
Old Jan 15, 2008 | 06:11 AM
here is a good how to on the SAFC
http://www.roadraceengineering.com/newafcsetting.htm
the reason for the wideband is to what what a/f ratio you are running. And the safc is to tune the a/f ratio. So yes you need both
Old Jan 15, 2008 | 05:03 PM
I wonder how bad the motor is by now....
Old Jan 15, 2008 | 09:40 PM
newguy2007's Avatar
what can i do to fix it. Im gonna turn the psi down to 20. I dont want to **** anything up.
Old Jan 16, 2008 | 07:25 AM
once you have a wideband you can check your current tune by watching the A/F ratio. You should be somewhere around an 11.3 But i posted in your other thread about the link for hks
Old Jan 16, 2008 | 05:28 PM
TheAdvocate's Avatar
Just curious... Do you have any ticking/knocking coming from your motor? Or does it run and sound smooth?
Old Jan 16, 2008 | 05:44 PM
newguy2007's Avatar
no ticking or knocking. It sound smooth but i turned the boost down to 20 today just to be safe. My low setting is at 1.00kg/cm and my high is at 1.43.
One question though, i had my car turned on(first time for a while) and changed all my boost settings and then i turned it off and back on and it says my low boost and high boost are at .48 and .49(goes back and forth) Do i need to run my car a little to build the boost up to the levels i set?
I have a pretty good understanding now of the evc so i think i did everything right. Now im going to learn about the safcII
Old Jan 16, 2008 | 07:19 PM
well it has to fully spool to hit the high boost setting which usually take till about 4k rpms. But the best way to tune is in third gear starting at a low rpms and flooring it till you top out
Tyler1325
Jun 21, 2008 05:54 PM
Angie
Nov 4, 2005 06:17 PM
mr.dash
Aug 28, 2005 04:23 PM
corks42
Apr 2, 2005 09:18 PM
rufio
Mar 13, 2004 02:17 AM
