bad news
absolutly right, although i really don't want to get on there bad side because my turbo kit and all my other parts are from them so if i need something i don't want them to be dicks about it, but im not trying to be an ******* about it i just want them to do whats right and i hope they understand that.
still the car runs bad,instead of the intercooler im running it nonintercooled until i get a new or fixed one. And the car still runs bad but it will run fine until it's fully warmed up and then it will start to misefire and it will start to run really bad when i start to loose vacuum on the boost gauge. This will all start when the car is fully warmed up. I just dont get it i'v replaced so much and fixed the leaks in the piping and still runs horrible, it will drive alright it's just mainly the idle although i haven't drove it far so mabye it would act up while driving it. It started about three months ago when i got stuck in a storm and drove through some high water, so i dried out my airfilter and mas. The car ran perfect for a couple days after that i got about a mile from the house and my car stalled after i hit some railroad tracks not saying that's what caused my car to stall by knocking something loose etc. I tried the whole night to get it to start and nothing,and the next morning i went to try and it started but i had to give it some gas. And that's when the rough idle started. I know i'v stated this before but i'v replaced plugs,wires,coil packs,maf,o2 sensor,compression check 185/190 psi across board,pcv valve,checked egr valve for proper function. The only code that comes up is random/multiple cyl misefire detected. The only thing i can think of is a vacuum leak somewhere i just can't find one.
