boost controler
Old Apr 19, 2006 | 10:46 PM
jdm2ner's Avatar
Default boost controler
ok so i have a 50 trim turbo that has an internal wastegate set for 7psi. now i have a turbo xs boost controller. when i instaled the b/c my boost went from 7 psi to 12 psi while the b/c is fully closed. i know konw i instaled it right , i have the flow of the of air coming from the turbo then i have it going to the wastegate. has any ever had this happen to them? i jecked for boost leeks have none. vaccume leeks have none.
Old Apr 20, 2006 | 12:12 AM
Default RE: boost controler
my boost controller only will give me a minimum of 12PSI but I think the Waistegate is what limits it??!!??
Old Apr 20, 2006 | 01:43 AM
NESpeed's Avatar
Yes all MBC have a low limit to the psi, kinda sucks. Maybe try a different controller.............
Old Apr 20, 2006 | 06:51 PM
DSMTalonAWD51's Avatar
why would you be running a 50 trim at 7psi anyway
Old Apr 22, 2006 | 11:14 AM
jdm2ner's Avatar
ist not that i wanted to run 7 psi is that i want to run 18psi but i did not want to blow my engine up by going over 12psi un tune. i am going to have my car tune today for 18psi i will write back an post my results.
Old Apr 22, 2006 | 12:42 PM
ORIGINAL: jdm2ner
Nice... Dyno tunigng it? maybe get some #s and charts
Old Apr 22, 2006 | 08:30 PM
jdm2ner's Avatar
well i was unable to tune my car. tuner found an exshuast leek between the manifold and the turbo. one of the treads were striped out. tuner said it would be useless to tune because after it would get fixed i would need to tune again. The shop said they would have to retap the turbo but it would be hard because it is cast iron.
2slow
May 16, 2007 03:43 PM
anko_kun
Dec 24, 2006 07:48 PM
T76 turbo
Apr 16, 2004 04:53 PM
Pinser555
Mar 5, 2004 10:00 PM
Pinser555
Feb 28, 2004 03:55 PM
