boost issues
Old Jun 16, 2007 | 12:45 PM
2slow's Avatar
Default boost issues
okay i finally got a bov that works now i'm having an issue w/ boost control when i'm cruising in fourth gear at 2000 rmps and put the pedal to the floor my boost guage shoots all the way up to 25psi then settles at 15 lbs which is my target boost , my question is should that be happening i have my manual boost controller turned all the way down ,the reason i ask is i don,y want to end up hurting the motor or the turbo?
Old Jun 21, 2007 | 05:20 PM
TheAdvocate's Avatar
Default RE: boost issues
Your wastegate is prolly crap.. Its not good if your motor is going that high... But once you go over 19-20 psi you should be feeling fuel cut... (If your running stock setup)
Old Jun 22, 2007 | 05:28 AM
Start by first making sure your boost guage is still hooked up correctly, then check to make sure you MBC is hooked up correctly. Im willing to bet its one of those two things. If not then i guess it could be the wastegate
Old Jun 22, 2007 | 08:21 AM
RCJr9186's Avatar
are you running a stock turbo and setup?
EVO4L
Mar 10, 2008 10:33 PM
anko_kun
Dec 24, 2006 07:48 PM
T76 turbo
Apr 16, 2004 04:53 PM
Pinser555
Mar 5, 2004 10:00 PM
Pinser555
Feb 28, 2004 03:55 PM
