check engine light codes
Old Jul 20, 2008 | 08:36 PM
spyder4g63t's Avatar
Default check engine light codes
check engine light ..ran these codes...p1104....p0110......p0100.....p0105
Old Jul 20, 2008 | 08:51 PM
dsm1990gsx's Avatar
Default RE: check engine light codes
P0100-volume air flow circuit malfunction
p0105-baro pressure circuit malfunction
p0110-intake air tempcircuit malfunction
p1104-turbo wastegate solenoid malfunction
Did you just do any work to your car?
Old Jul 20, 2008 | 10:12 PM
Vac lines are fuuuucked
Old Jul 21, 2008 | 06:52 AM
Its probably one of two things
1. The ECU is bad
2. The Mass Airflow Sensor (MAF) is bad.
However even though the ECU is the more expensive i would start with that. Maybe try and find someone that will let you borrow one to give it a try.
Old Jul 21, 2008 | 10:49 AM
so the ecu or mas can be causing poor accerleration and the choppy feeling?..so i should get my mas and ecu and vac lines...and exhaust leak....those could be the main reason.....im just tired of dealing wit ****ty mechanics....i took it a couple months ago and told them to check everything....from fuel to lines...and obviously they didnt do a good job......just want to make sure cause if i tell them to check that specifically maybe they will <sarcasm!...thanks alot fellas...hopefully those are the prob so i can take care of it....tired of drivin a ****ty dsm...
Old Jul 21, 2008 | 11:27 AM
dsm1990gsx's Avatar
Try unplugging the maf and driving it and see if its any better. I am betting on a bad maf.
Old Jul 21, 2008 | 11:48 AM
well i drove with out the mas..both good and bad....ofcourse it ran chopppy upto 2300rpm then it halled ***...that could be the cooparate..but instead of buyin a new mas can i just get a maf translator to also run open b.o.v and take care of the problem
Old Jul 21, 2008 | 05:04 PM
dsm1990gsx's Avatar
Get a used 2g mas, you can get them dirt cheap. Running a gm maf is very expensive and can be a pain to tune. One more thing dont get the gm maf just so you can vent your bov.
Old Jul 21, 2008 | 05:20 PM
After you replace the MAS, be sure to unplug the battery for a few mins to let the ECU reset. Then you should be good to go.
If not, then you have other problems.
Old Jul 21, 2008 | 06:23 PM
i still havea feeling its the ecu. but you can try the maf first
