confused on a few things...
Old Aug 28, 2006 | 02:29 PM
hatchetman9449's Avatar
Default confused on a few things...
1. ok... i just read that there is a certain 1.8 that is just not able to be swapped with the 4g63.. is that true? if so, what one cuz i dont wanna get the 4g63t to swap it then not be able to.
2. i found a 4g63 non turbo for 700 bucks with only 40k miles on it... im gunna buy it if i can do the swap. then i wanna put an EVI III 16g turbo on it, but i also heard that when i put a turbo on there i will need to change the ecu, wiring harness, headgasket, cams, and injectors ect. is that true? if so how much will that run me?
Old Aug 28, 2006 | 02:31 PM
slow420a's Avatar
Default RE: confused on a few things...
1. > no idea
2. > more then what its worth, the oil spouts in the block are different and the pistons/rods are different, bottom line, it will work, but it will be less work if you buy a turbo 4g63.
Old Aug 28, 2006 | 02:51 PM
i think what he is maybe talking about slow is the 2g eclipse N/T that comes with the 420a where you cannot swap in the 4g63. But then again that engine is a 2.0L so maybe thats not what your talking about. But as long as you have a 1g then the 4g63t should be able to be swapped in there.
Old Aug 28, 2006 | 06:31 PM
ok, thanks guys i will keep looking for a 4g63t. i found one but its 1500.. so will i save buy buying that or the n/t for 700 and converting??
also, im looking for used 2.0 4g63t's and i found some that are 7 bolt. im guessing thats for the 2g's but im not sure.. another thing i found a couple times is a 4g64 sohc. is that any good? and will it fit in my car?
Old Aug 28, 2006 | 08:21 PM
slow420a's Avatar
the 7 bolt was produced from 92.5 -94 in the 1g, so yes it will fit, in a nut shell 6 bolt>7 bolt becuase its crank wont walk(crank walk).
For the 4g64, its the same thing as a 4g63 but its a 2.4 sohc. Its the motor that comes in the 3g eclipse gs/rs and the 2g eclipse spyder gs. Its not a bad motor but the 4g63 has more potential.
Old Aug 28, 2006 | 08:44 PM
thanks alot man. but what one will save me more, the 700 dollar 4g63 and upgrading to turbo, or 4g63t for 1500 dollars? either one i get im putting a new turbo on so dont include that.
Old Aug 28, 2006 | 10:47 PM
slow420a's Avatar
Honestly they would be about the same in the end, the 4g63 non turbo may be a little cheaper but its going to take alot of time and work to change over. If I were you, I would head down to the local junk yard and see if you can get your hands on a 6bolt short block, throw in some j.e. pistons, some eagel rods. Then order a ported/polished head off ebay strap that on with a mls headgasket and drop her in. It would cost a bit but you would have a nasty motor to work with.
Old Aug 29, 2006 | 01:31 AM
ok, ill look into that... thanks alot man
Old Aug 29, 2006 | 10:17 AM
well right now i still have my 6 bolt laying around
Old Aug 29, 2006 | 05:26 PM
is it turbo, and how much bro?
it comes with the complete engine right?
