FMIC????
Old Mar 9, 2007 | 12:30 AM
cologsx's Avatar
Default FMIC????
Okay I'm looking at an English Racing 7" FMIC for two reasons. 1 is I need a new bumper anyway b/c mine's cracked and 2 is my SMIC is beat to hell. Some @$$ removed the inner fender well at some point so there isn't anything between the tire and the IC. I don't want to confuse the car by replacing the fender well anddoing something right, hell I just gotit running right and the strain may be more than she can bare. I like the way a FMIC looks but is this a bad idea? I still have the T25 and it runs 15 lbs, would a 650 cfm @ 1.5 psiFMIC be to big for me? Thanksfor your thoughts.
https://englishracing.net/catalog/pr...roducts_id=685
Old Mar 9, 2007 | 01:11 AM
Default RE: FMIC????
Yes, an intercooler that size will lose you power. On the stock T25, the stock intercooler is adiquate.
Old Mar 9, 2007 | 08:40 AM
paintballproam's Avatar
Thats the 7" ETS kit from extreme turbo systems/extreme intercoolers. You will loose power if you try to use a front mount with the t25. However if you upgrade the turbo, i recommend just going with the 10.5" kit like i did. You wont really notice any amount of lag and you will have much more room to grow.
Old Mar 9, 2007 | 10:45 AM
RCJr9186's Avatar
if you do get this for the look i'd also suggest getting an boost controller to bump the boost up a bit, these turbo's areeffecient up to about 19psi i believe...
Old Mar 9, 2007 | 10:47 AM
It will slow you down but it is a good upgrade if you plan on swapping the turbo at some point anyway
Old Mar 9, 2007 | 10:52 PM
cologsx's Avatar
okay, last night I decided to just upgrade the whole damn thing. Evo III big16g, Evo IIIO2 housing, and Evo IIImanifold, Dejon FMIC, another BOV and all the piping. I know I need to upgrade the fuel system, any suggestions on pump, injectors, etc.... Thanks
Old Mar 10, 2007 | 12:12 AM
for that setup, id say go with a walbro 255 (might as well) a 190 would probably work as well though. And id say 550's on the injectors
Old Mar 10, 2007 | 12:56 AM
cologsx's Avatar
good deal, thanks.
BrunoBoy650
Apr 8, 2006 05:51 PM
ziggy88
Mar 17, 2006 01:00 AM
get435
Dec 18, 2005 09:55 AM
DSMDUDE
Mar 30, 2005 09:59 PM
t3t4turbo
Feb 20, 2005 03:25 AM
