How much boost you reken
Old Jan 10, 2007 | 11:49 PM
BlackMurcielago's Avatar
Default How much boost you reken
Okay my six bolt is being sawpped in this weekend and hes throwing in a Manuall boost controll, boost, air/fuel, and oil psi gauge.
Its a 6-Bolt
Has 4 Layer Head gasket
and ARP Head studs
The gaskets can hold 80 and the studs around 120 pounds
But my question how much boost i can safly run on that crank, stock pistons and rods. Im putting in a 25/28 BB turbo to.
So what do you guys think
Old Jan 11, 2007 | 12:39 AM
Default RE: How much boost you reken
On that turbo...20 safely
Are you running stock fuel?
Old Jan 11, 2007 | 01:10 AM
Stock injectors, rail, pump, and Electronics
Old Jan 11, 2007 | 02:23 AM
um.... 15-17
Old Jan 11, 2007 | 04:06 AM
ORIGINAL: BlackMurcielago
why even ask then lol.... If its a bigger flowing turbo than stock you may even not want to push more than 15
Old Jan 11, 2007 | 08:43 AM
paintballproam's Avatar
It depends on the turbo. Im not going to say you can run 17psi because if you have a T25, then thats fine, but if you have something like a FP3065 or GT40R, your motor will blow. It depends on the flow rate of the turbo. On a stock turbo however, 15 would be good.
Old Jan 11, 2007 | 08:39 PM
TheAdvocate's Avatar
ORIGINAL: EMonz57
Same.. 15 would prolly be good for you..
Old Jan 11, 2007 | 11:50 PM
What if i do get larger injectors, lines, pump, rail and all that
Old Jan 12, 2007 | 08:21 AM
What turbo are you going to run? Even if the 6 bolt is stock, they have been known to handle 400hp+.
Old Jan 13, 2007 | 08:51 PM
I wouldnt go over 18lbs with even after those upgrades.. But if its your daily driver and you dont want to start fixing things, i would stick with about 16-17..
gstTurbo2011
Sep 8, 2006 12:00 AM
thehintons06
Jul 25, 2006 10:31 AM
thehintons06
Jul 12, 2006 07:08 PM
B.e.R.a.T
May 10, 2006 02:46 PM
turbobird14
Aug 8, 2005 10:37 PM
