Ideal evo III oil pressure?????
Old Sep 21, 2007 | 10:29 PM
98evo3's Avatar
Default Ideal evo III oil pressure?????
I have installed a Evo III turbo on a snowmobile. I have been searching for the oil psi specs for this turbo andcan't seem to findmuch if any specs for the oil flow psi. I am suppling oil with a machnical pump that gets the oil from a reservior that I have built. I know that the journal bearing turbos need more oil pressure than a ball bearing turbo but I am not sure just how much pressure flow they need or can handle. If someone could point me in the right direction, or give me an idea where I can fine this information I would be greatful. ( Been looking for quite some time.) Thanks!
Old Sep 21, 2007 | 10:34 PM
Default RE: Ideal evo III oil pressure?????
As long as its pushing over 15 i think it will be fine
Old Sep 23, 2007 | 12:44 PM
98evo3's Avatar
Over 15 psi? But how much is to much?
Wow I have been told that 20 psi is good for running a ball bearing turbo and that they can operate at alot lower oil psi than a journal bearing turbo. I was also told to operate the evo III tdo5h at 30 psi at idel and 50 psi operating. Then I read on another forum that the oil pressure on the 16b should be ran at min. 45-61 max.psi of oil pressure. I have read that if you run the oil pressure to high that you may ruin the bear seals.
I am willing to try any pressure but i don't think the bypass valve I have will even let me run the oil pressure that low,(15psi) even wide open. I think its range is from around 25 - 80. I just don't want to ruin the bearing seals with to much pressure.
Thanks for the help, Is there any shop manual that has the evo III turbo oil pressure operating specs?
Old Sep 23, 2007 | 12:57 PM
No sorry i cant answer any of that confidently.
However, i think your fairly right with what your saying. Call it 35?
paintballproam
1st Generation
Apr 17, 2006 08:27 PM
slow420a
Jan 11, 2006 01:24 AM
Prophet
Oct 10, 2005 02:39 PM
STACYYY23
Jan 9, 2005 04:01 PM
