Intercooler installation help
i have a 99 eclipse GS-T Spyder. i jus bought a stage 3 16G EVO turbo, Stage 3 Greddy Blowoff Valve, OBX Intercooler, 3 inch catback sytem with freeflow cat, and a 3 inch downpipe. i need to know how to install the intercooler so that my car still looks stock,. Also what kind of injectors should i buy for this setup? any info will be much appreciated
on a 16g (not sure what stage 3 means..... or a stage 3 bov... what is that?) a good injector size would be 550's. you can get 650's or 660's but you will need a FPR if you go that high. as for installing the FMIC.... what do you mean stock? as in, so that you can't see the intercooler? it will take some serious work is all i have to tell you, you would have to mount it horizontally somewhere, not sure where. another option would be to go w/ a liquid to air IC. you are aware that you will also need fuel pump, tuning device, ic piping, couplers, boost gauge, boost controller and a tune to see a noticible difference right? after you get ur car going, you'll need a new clutch not after to long.
Xicer
Nov 29, 2013 03:19 PM
