looking for hahn installation instructions
Old May 14, 2006 | 04:04 AM
GuidoSalducci's Avatar
Default looking for hahn installation instructions
looking for a set of installation instructions for the hahn setup, or the star setup. doesn't matter. gonna use it as a guide to build my own setup for the 420a eclipse. i have an ongoing parts list but already have a manifold with external gate setup, and a td04-h i got for 10 bucks and then rebuild for cheap money. if you have an updated parts list that i'll need. please add to it. no flames please. I don't wanna hear about how the 420a can't be turboed. or how you think its a useless project.
Old May 14, 2006 | 10:56 AM
slow420a's Avatar
Default RE: looking for hahn installation instructions
http://home.bendcable.com/optimuspet...nsturcions.htm
225 walbro
vortech sfmu
-10 feet of #4 S/S fuel hose
-2 Feet of #4 S/S fuel hose cut in half.(optional if you wish to put a fuel press sensor there)
-5 -4AN hose end fittings
-1 -4AN union Tee
-3 feet of regular fuel hose (or S/S fuel hose.. i just forgot to get a little extra)
-Universal Fuel filter (about $8) make sure it is for fuel injection systems!!
-6 hose clamps this will give you an extra one just in case
-2 -6AN (female) to -4AN (Male) reducer.
4 feet of 1/4 inch fuel line, 4 1/4 inch hose clamps
Theres your fuel system, with a return line setup. Rember your stock injectors max out at 9psi. If you want more boost then that your going to have to rebuild your motor and get some bigger injectors.
I would also recomend that you get...
a missing link or fcd
Hit up e-bay for a hahn fmic kit or just a fmic, but you would have to fab up the piping.
For oil lines...
http://cgi.ebay.com/ebaymotors/T3-T4...65243080QQrdZ1
A kit like that would do, but you would also need to buy the an fittins for the hose and a WELD in oil pan bung for the dump tube. The gay ones you drill and bolt leek.
For a down pipe you can get all of the flanges that you need from roadracingengineering.com and summitracing.com. All of the fuel fittings/hose can be found at summit to. The sfmu your only going to find at vortechsuperchargers.com or on e-bay. If you need more detailed instructions or if you want install instructions for the fuel system pm me.
myevobaby
Feb 4, 2008 05:36 PM
myevobaby
Feb 1, 2008 11:51 AM
bling bling
1st Generation
Aug 25, 2005 07:45 PM
gambit_710
Jun 10, 2005 11:12 AM
gambit_710
Jan 27, 2005 06:41 PM
