MBC wont increase boost
Old Jul 21, 2006 | 01:34 PM
99clipsgst's Avatar
Default MBC wont increase boost
I got a Joe P MBC and followed the diretions that came along w/ it. At first the boost was at 10 PSI so I adjusted the screw and it went to 12 psi or so. which is what I was at w/ out a boost controller. then I adjusted the controller 3 more times and the boost wont go up any more. am I forgetiing something or do I need to adjust my BOV.
Old Jul 21, 2006 | 08:14 PM
Blue03Evo's Avatar
Default RE: MBC wont increase boost
Your BOV may be leaking so i would try that or you may need a stronger spring in the MBC.
Old Jul 22, 2006 | 12:39 AM
slow420a's Avatar
Joe p mbc's are worry free, their the cheapest most reliable mbc on the market. If you have a stock bov, which I am guessing you dont becuase you said that you may have to adjust it, the stocker will only hold 12psi, everyhting else leaks out. Did you happen to remove you bcs? 2g's have a little restrictor in the vac line that goes from the compressor housing to the WGA which will keep it from going over 12psi. Check out vfaq.com for pics of mbc installs.
Old Jul 22, 2006 | 10:52 AM
99clipsgst's Avatar
I have a greddy type s bov. And yes the BCS restrictor had been removed before i bought the car. when you put the mbc on can't you remove the bsc. I havent but its only connected on one side and the is to the intake. do yoy think that if I adjusted the bov to harder it might fix the problem?
Old Jul 22, 2006 | 04:02 PM
importorigins's Avatar
Would that also work for the hks mbc? The instructions that came with mine were a bit confusing. lol
ORIGINAL: slow420a
Old Jul 22, 2006 | 09:03 PM
slow420a's Avatar
hit up vfaq.com
Old Jul 23, 2006 | 02:48 PM
99clipsgst's Avatar
I went there and for the hallman mbc you hookit up to the bov. Is that right? in the directions it says to run it from a pressure source and the wastegate. so I have one end connected to the wastegate and the other to the nipple on the turbo housing. Any other pics of other setups would help
Old Jul 24, 2006 | 11:22 AM
ORIGINAL: 99clipsgst
thats how it should be hooked up. I think slow is right on this one. I dont think it has to do with your MBC. Something else is leaking preventing it. I would try tighting the spring in it. If that doesnt do it then check the intercooler pipes for a leak.
cerberus9
Apr 5, 2007 08:45 PM
paintballproam
Jul 7, 2006 11:52 AM
19eclipse91
Apr 25, 2006 06:57 PM
TheMongoose
Jan 28, 2006 01:12 AM
GSX~speedjunkie~
Jul 17, 2005 06:32 AM
