Now What?
Old May 10, 2006 | 08:20 PM
PooT_Nation's Avatar
Default Now What?
Ok,
So I've bought a Manual Boost Controller and a Boost Guage off of Ebay and am awaiting their delivery.
Before installing these, Do i need anything else? I'm planning on boosting the stock turbo to 15psi.
I'm not interested in too much power and I believe i'll get a little bit more when pushed up to 15psi.
But do i need anything else? I've already got the Exhaust, Intake, BOV, etc etc.
About how many horses do you think i'll be pushing?
Old May 10, 2006 | 09:54 PM
Default RE: Now What?
you are good to go at 15#s you will be ready to run maybe high 13s if you can launch and you have a Dp and no cat
Old May 11, 2006 | 12:15 AM
00Mirage's Avatar
man this turbo stuff sounds confusing, but i was thinking about getting a charged car, is it really that hard to maintain or is it just common sence?
Old May 11, 2006 | 01:27 AM
I would recommend to learn it before getting into it. With out basics at the very least you can blow your motor really easy, or if you know what your doing you can make big power safely. When it comes to tuneing make sure it gets done and done right.
maintenance is not back no diff really than an NA car. Just as long as you know what things to do, like Time the turbo before shutting the car off if you dont have a turbo timer
Old May 11, 2006 | 04:47 AM
so I'm assuming i don't need anything extra.
And what i assume you said Emonz, is that At this point i'm running 15s and after boosting more ill be running high 13's
Old May 11, 2006 | 08:14 AM
ya your all set, you could be running high 13s with a launch im guesing
Old May 11, 2006 | 10:24 AM
slow420a's Avatar
ORIGINAL: PooT_Nation
Possibally, rember you will be making even more hp when you get a fmic though.
Old May 11, 2006 | 07:21 PM
ye def, but i can't afford a FMIC yet.
Manual Boost Controller and Boost Guage off of EBay = under 100 bucks = easy
Good FM off Ebay = 400-500 = hard/bad
Maximus99
May 13, 2005 04:27 AM
1398spdr
Sep 11, 2004 02:40 PM
91eclipse
Apr 28, 2004 04:45 PM
forza
Jan 10, 2004 02:33 PM
oni24u
Apr 21, 2003 03:05 PM
