Turbo upgrade need opinions
Old Apr 22, 2006 | 11:24 AM
n2daizo123's Avatar
Default Turbo upgrade need opinions
I have a 1996 fwd dsm thats stroked to 2.3 liters, my over all goal is between 350-400 crank hp. what would be the best turbo? I also am getting a quaife lsd, act 2600 clutch, and some proxes ra1s so i can put it to the ground.
Old Apr 22, 2006 | 12:41 PM
Default RE: Turbo upgrade need opinions
Big 16g turbo. can make around 390HP at 22\24PSI with other supporting mods
Old Apr 23, 2006 | 11:21 AM
TheAdvocate's Avatar
Even a 20g would be good for you.. A little more turbo lag but it would give you suffecient hp..
Old Apr 23, 2006 | 03:20 PM
ORIGINAL: TheAdvocate
I didnt want to recomend it because I see alot of 20Gs blowing up easy. and the 16G is enough to get his goal. EVOs are hitting 400 on the 10.5H 16G my 16G is a 9.8H and only gets like 380ish and then the small 16Gs only go like 360ish
Old Apr 24, 2006 | 09:45 AM
n2daizo123's Avatar
what about a hahn 20g?
Old Apr 26, 2006 | 08:23 AM
hahn makes good turbo's.. Your gonna be paying the price for it though..
Old Apr 28, 2006 | 10:58 AM
ORIGINAL: n2daizo123
20G seem to break alot IMO, but it is also not resonible if your goal is only 350-400 then the 20G is going to far. I would stay 16G that will be right in your range of power
Old Apr 30, 2006 | 02:20 PM
Padro1712's Avatar
I was looking into it because im gonna get a gsx and theres a turbo upgrade for the gsx/gst. the GT30R and it gives you 400 hp. You should look into it.
Old May 14, 2006 | 12:45 AM
GREDDY_GST's Avatar
I have the GREDDY 18g upgrade and a bunch or other **** like injectors and safc and fuel pump ect... and because of stock internals and not wanting to blow my car sky high im running about 300 hp and the turbo is only turned up about 50%..... and it goes realy well.
EVO4L
Jan 27, 2009 01:17 PM
MitsiGTO
May 15, 2007 07:56 AM
novetek
Feb 2, 2006 03:18 PM
mitsuboi18
Apr 12, 2005 12:46 PM
96EclipseGS
Feb 14, 2005 10:53 AM
