need help turbo upgrade
Old Jan 31, 2006 | 03:57 PM
novetek's Avatar
Default need help turbo upgrade
I have a 95 gst with basiclly bov intaked ic and clutch and my homiegave me a toyota ct26 i was wondering what would the hp and tq be and what else would i have to replace n whats the best size piping? thanks for the help I'm new at turbo n jsut tryin to get some info thanks
Old Jan 31, 2006 | 04:53 PM
Default RE: need help turbo upgrade
what is that turbo from? and getting you HP #s all depends on modds boost and the turbo..if it cant flow very well than you may never even se 300WHP with it. I know the big 16G mitsu turbo can max at around 380HP and the s,all 16G is like 360ish ir something but im not fimialar with this turbo your talking about
Old Jan 31, 2006 | 06:52 PM
novetek's Avatar
I guess its out of the supra
Old Jan 31, 2006 | 09:35 PM
ORIGINAL: novetek
well suprea Turbos are honestly not that great... they flow the best at 18 PSI (assuming its a MKIV supra) any higher and they wont last long... it is prob better than the stock T25 but im not sure on how it flows. the older supras im not sure of they I would guess had a little weaker turbo otherwise someone would swap 2 of them in as a minor upgrade.... again I am not sure on this one just spitting out ideas
Old Feb 1, 2006 | 02:33 PM
novetek's Avatar
thanks for the info then...what would be a decent turbo upgrade? for a decent price or should I just keep the old turbo and just get a boast controller....
Old Feb 1, 2006 | 05:06 PM
NESpeed's Avatar
Take Emoz advice and trash the T25 you have, and at least pick up a small or big 16G. Start there and build off of that when you have maxed out either one of those. By that time you'll have a much better understanding of what turbo you will want to go with according to the type of power application you want. The 16G turbo is a great all around turbo you wont be disappointed. Yes the ct26 turbo was in the early 90's supra's when they where single and also MR2's. I have never heard of someone putting that on a DSM. Ill see if I can find a compressor map for you. Then we can see if it would be worth your time to at least try it.
Old Feb 2, 2006 | 03:18 PM
novetek's Avatar
i really appreciate all the info n no ragging thanks now i know who to talk to on this forum
EVO4L
Jan 27, 2009 01:17 PM
MitsiGTO
May 15, 2007 07:56 AM
n2daizo123
May 14, 2006 12:45 AM
mitsuboi18
Apr 12, 2005 12:46 PM
Mrfirefox
Jul 10, 2003 06:14 PM
