Please teach me
Old Jun 16, 2006 | 03:02 PM
hostl's Avatar
Default Please teach me
I am very new to modding my car and want to learn. I have a 2004 eclipse GS and want to Install a turbo that has these parts. USED FMU (fuel management unit)
- 12:1 Vortech FMU
FMIC (front mount intercooler)
- ( 2" THICK )
- ( 34" LONG )
- ( 5" HIGH )
- 2.5" inlet, 2.5" outlet
- Tested at 30 psi with no leaks
FUEL PUMP
- Walbro 255 in tank fuel pump
Manifold
- 2G Manifold painted with high temperature black paint
BOV
- 1G BOV
O2 Housing
- 2G O2
APEXI SAFC
-Apexi safc
TURBO TIMER
-GREDDY
NEW FRONT MOTOR MOUNT INSERT
-Polyurethane motor mount insert by energy suspension
Faze turbo boost glow gauge
Turbo bolts
Oil drain flange
manual boost controller
Can anyone think of anything else I am gonna need and will I need to flash my ECU. I was alos told that I will need to get bigger injectors or the stock ones will melt, is this true. Any and all help will be appreciated. Thanks in advance.
Old Jun 16, 2006 | 03:17 PM
Default RE: Please teach me
First off, what type of turbo are you gonna put on the car?
Old Jun 16, 2006 | 03:57 PM
hostl's Avatar
T-25 TURBO it is used but it has no shaft play whatso ever. But later I do plan on upgrading to a t3/t4.
do i need to flash my ECU and get bigger injectors or will the ones I got now work?
Old Jun 16, 2006 | 03:58 PM
hostl's Avatar
T-25 TURBO and do I need to flash my ECU and will I need to get bigger injectors I was told my current injectors will melt?
Old Jun 16, 2006 | 04:41 PM
well i think the 255 fuel pump is overkill. I would stick with the 190.
Old Jun 16, 2006 | 05:36 PM
hostl's Avatar
Well I already bought it but how about the injectors and ECU and is the turbo big enough?
Old Jun 16, 2006 | 06:48 PM
Thats a real bad idea...
Old Jun 16, 2006 | 07:12 PM
hostl's Avatar
well thats alot of useful information. See I came here cause I needed help because I dont know about modding and I'm sure you guys were where I was at one point but dont tell me its a bad idea and dont tell me why its a bad idea because I'm not gonna learn like that, because I went to tearstone.com and saw that the fuel pump http://tearstone.com/shop/index.php?...emart&Itemid=1 was for my car. I hope I didnt step on anybodyz feet I just came here cause I wanted to learn. And can somebody tell me about the ECU and the injectors will i need to flash and get bigger injectors
Old Jun 16, 2006 | 07:13 PM
Oh boy...
The SAfCII doesnt work well with the 3G eclpses. It will erase your memory and override to stock settings, it has happend to me in the past. I would highly recommend the Emanage.
Some will say the ECU resetting tunes is a myth but my 00 GS did it. Tearstone runs the Emanage with no troubles though
Old Jun 16, 2006 | 10:14 PM
hostl's Avatar
The fuel pump came with the kit I bought, why is it a bad idea? will it be to big for my car or are there known problems with it?
