Turbo fitting help!
Hello!
I've been searching everywhere to find out some info on a turbo I have. Apparently it is a TD04HL-13T off of a RVR. My question is this:
Does anyone know what size fittings I need for the oil supply and return or drain?
Like -4AN or -6AN for example. It's for a custom application. It also didn't come with any so I have nothing to compare it to.
Thanks for your help!
M
M
Hello Everyone,
I'm fitting a Garrett Turbo to my 2005 Mitsubishi Triton as the original turbo has blown up.
The turbo that I have bought of someone is a VNT Turbo and Requires a Vacuum line for the actuator.
The problem I'm having is that I'm not sure where I can get a vacuum line from?
Can it be any vacuum line from the engine or does it have to be from a specific place ?
If anyone could help me out that would be great,
Thanks.
Thanks.
