Turbo help please
Old Sep 25, 2006 | 10:30 PM
Gkel's Avatar
Default Turbo help please
Well im sorry for you members that already know everything about these engines. but ive got to ask this just to be sure now i did read some stuff about doing a turbo on these forums but im not to for sure. right now im selling my car and i plan on getting my dads 93 eclipse gs with the 2.0 now im guessing these are the engines to use not the other one (420a) but im guessing the internals need to be changed out because they wouldn't be able to handle the turbo. what im really asking is it fine to put a turbo on and what needs to be changed out. and the car has 120 thousand miles on it and has been owned by my family since it was bought new so its been treated right oil changed etc, thank you
Old Sep 25, 2006 | 10:34 PM
Default RE: Turbo help please
so... its not a 420a?
Old Sep 25, 2006 | 10:40 PM
Gkel's Avatar
im not for sure is it i thought those engines were in the newer eclipse's. im not too for sure im still learning about this engine. sorry.
Old Sep 26, 2006 | 10:23 PM
slow420a's Avatar
1g non turbo cars had a non turbo version of the 4g63.
Old Sep 27, 2006 | 02:03 AM
Gkel's Avatar
so would the pistons and camshafts be ok on the car if i decide to put the turbo on.
Old Sep 27, 2006 | 09:41 AM
it depends on what you plan on putting in and how much boost you want to run. I think with a small 14b turbo or something running low boost like around 8psi the internals would probably be fine. But thats not gonna get you very far. If it were me i would put new internals definetly so that there is breathing room.
Old Sep 27, 2006 | 09:44 AM
slow420a's Avatar
crank: yes, nearly everything else.... no lol.
When mitsu made the 4g63 it was orginally a non turbo carb motor. When they decided to put it into productin they based the 4g63t off the motor. So basically what we(the consumers) are left with is a turbo motor that was based and improved off a non turbo motor... instead of the other way around. To make a long story short alot of things are different. The 4g63 non turbo can never be exactly like a 4g63t because even the blocks are different(the non turbo has different oil spouts in the block). If you want to make it similar to a 4g63 t though your going to need to change the.... pistons, rods, cams, injectors, ecu, and headgasket on top of the turbo setup.
Old Sep 27, 2006 | 08:45 PM
I would recomend simply doing a 4g63 swap... it will be that simple
Old Sep 30, 2006 | 01:31 PM
NESpeed's Avatar
ORIGINAL: TheEngineer
Unless you replace the wastegate spring the 14b will not run less than 10 psi, but john you know that right.....................
enzo_hashmat2006
Oct 10, 2017 05:46 PM
lgibson
Mar 12, 2009 07:04 PM
gargola1227
May 21, 2005 03:16 AM
gargola1227
May 3, 2005 03:10 PM
Watts9614
Sep 15, 2004 02:04 PM
