97 mirage no codes no star
I have this 97 1.8 litre mirage ,when I hook up obd 2 diagnostic tool it reads as no codes found...now the battery was dead but it has since been charged...would that erase all previous codes ? can I test this main computermodule brain I have been toldif the brain is bad it will readas a no faults found reading any clues,mr Wizzard
You need to find out if you are getting spark or fuel.
So, remove a spark plug and crank it. Have someone watch the spark plug while you crank it.
If the injectors are working then the plugs should be covered in fuel after cranking.
