97 mirage no codes no star
Old Jun 26, 2008 | 02:10 PM
matsabishi's Avatar
Default 97 mirage no codes no star
I have this 97 1.8 litre mirage ,when I hook up obd 2 diagnostic tool it reads as no codes found...now the battery was dead but it has since been charged...would that erase all previous codes ? can I test this main computermodule brain I have been toldif the brain is bad it will readas a no faults found reading any clues,mr Wizzard
Old Jun 26, 2008 | 02:35 PM
Default RE: 97 mirage no codes no star
You need to find out if you are getting spark or fuel.
So, remove a spark plug and crank it. Have someone watch the spark plug while you crank it.
If the injectors are working then the plugs should be covered in fuel after cranking.
Old Jun 26, 2008 | 04:07 PM
dsm1990gsx's Avatar
Usually when an ecu goes bad you want have any communication w/ the scanner. And if the battery was completely dead it would erase the codes.
Davie-h
Nov 11, 2013 01:25 PM
membreya
Apr 18, 2013 12:50 AM
Niels
Feb 20, 2006 01:57 PM
norman11
Mar 4, 2005 04:02 PM
RayDiez
Jan 16, 2005 04:08 PM
