eclipse gt vs vr-4 and why
Old Oct 11, 2006 | 10:04 PM
  #31
Default RE: eclipse gt vs vr-4 and why
i really cant be botherd with it.
If anyone wants to PS it out for me and stick Mitsu Forum on it... be my guest.
Old Oct 12, 2006 | 12:00 AM
  #32
DeathCabForCutie's Avatar
here's the bigger question though......how much money and labor would it take to make a 3g eclipse as fast as a stock VR-4?
Old Oct 12, 2006 | 02:12 AM
  #33
davidmitsusrock's Avatar
i would assume not that much a vr-4 runs mid 13's that is very possible with a 3g on boost.
Old Oct 12, 2006 | 08:00 AM
  #34
ORIGINAL: DeathCabForCutie
only about $4000 or so on a GT.
Old Oct 12, 2006 | 10:15 AM
  #35
ORIGINAL: EMonz57
I hear bad things about and I know the 1 vr 4 has a weak bottom end that likes to spin bearins
yea it does seems to enjoy that
Old Oct 12, 2006 | 12:12 PM
  #36
Lil Evo's Avatar
Ok.........did I read right and you're wanting to drop a twin-turbo'd DOHC v6 into a Mirage? Do me a favor, take some mesurments and look at how crammed that engine is into the front end of that 3KGT, and then point and laugh at yourself for thinking it could be crammed into a Mirage's engine bay that is full with a 1.8L SOHC. It could be done, I suppose, but you'll be cutting out the firewall. Not to mention that you'll have to completely rebuild the front suspension to handle the weight, otherwise you'll have some insane nose plow going into turns, and you'll be fabricating all the engine and transmission mounts (hope you're good with a welder). Then there's all the wiring harnesses, you'll need a new ECU, new exhaust (cuz God knows that 1 5/8ths inch bendy straw they come with won't work), new transmission, front axles, ect. ect. ect. Should I continue? The Mirage isn't worthy of such an engine anyway. Just get the VR4, pull out some stuff to lighten it a bit and call it a day. Swapping would be a nightmare
Old Oct 12, 2006 | 01:42 PM
  #37
mitsu_madness's Avatar
sweet thanks
Old Oct 12, 2006 | 02:10 PM
  #38
ok, here is another question. in everyone's mind, which year was the best vr-4 produced?
Old Oct 12, 2006 | 02:23 PM
  #39
well 98-99 was the rarest.
Old Oct 12, 2006 | 06:30 PM
  #40
correction 99 was the rarest less then 300 made. howver i would go with a 1g(91-93) couse they are cheaper
